    Jul 2009
    Illinois
    189
    9
    File size limitation need help
    I attempted to post a piping schematic of the system I have been working on and was stoped short by the file size limitations, can someone explain a way around this issue? Also I have found this web site is running really slow lately, perhaps it is some setting on my computer but all other sites load up fine, any advice would be appreciated, I really enjoy this site but it has become extremely annoying because of the long delay.
    Sep 2003
    ISRAEL
    65
    4,098
    37
    Re: File size limitation need help
    Apr 2009
    Panacea, Florida
    80
    9
    Did you try to zip the file? This will work on some graphics, although not on AutoCAD. Another trick is to convert it to .jpg and then change resolution to 100 dpi or lower, and resize to small. Recipients can enlarge and enhance after they download.
    Jul 2009
    Illinois
    189
    9
    Thank you,
    I will give both suggestions a try.
  1. Replies: 27
    Last Post: 05-03-2009, 11:20 AM
  2. Fujitsu Window unit Size 9 same size as 6 ?
    By S_Line in forum Air Conditioning
    Last Post: 19-09-2008, 01:05 PM
  3. Compressor size changeout (long post)
    By Firechicken in forum Fundamentals
    Last Post: 04-06-2008, 08:43 AM
  4. Urgent!!! S.O.S. - nozzle size
    By herefishy in forum Fundamentals
    Last Post: 25-05-2002, 10:29 PM
