Thread: Bosch Fridge Freezer to repair ?
28-04-2010, 05:52 PM #1
Hiya All...
I have a Bosch Fridge Freezer
model: KGE 3301GB/02.
I am getting an error message E2
I understand that it is a Thermistor
problem.
The fridge is warm ( not working )
the freezer is OK !
I read that you can re wire the front panel
at the top of the fridge to by pass
the thermistors but the wiring diagram I downloaded
was not for my model. I only have 2 wires
and a ribbon cable going to the pcb board.
Can any one help me out with instructions
on how to repair this fridge freezer ?
Thank you in anticipation
05-05-2010, 07:00 AM #2
Re: Bosch Fridge Freezer to repair ?
E2 error is an error sensor evaporator refrigerator.
It is in the upper right corner to remove insulation and dig up the sensor. It will be on the evaporator plate with a white cable.
After replacing a new sensor should be insulated with foam
13-05-2010, 09:04 AM #3
Thanks for you info ! well appreciated
20-05-2010, 09:21 AM #4
Thank you for the Info. I am not a Fridge/Freezer Engineer. When you say it's in the top right hand corner do you mean when your standing at the back of the freezer looking at it ? Could you please tell me how I get inside the fridge ? Do I need to cut a hole through the back of the fridge to reach the senser ?
20-05-2010, 02:58 PM #5
I have notice the Fridge/Freezer that was displaying the E2 ERROR has stopped displaying the error and has gone back to displaying a fridge temp.
I wonder if it is anything to do with this warm weather we are having previously the weather temp had been 10 to 14 deg C .But since we have had this warm spell 24 deg C. the fridge has been showing a proper temp ! Does anyone thing it will stay fixed or is it just temporary while we have this warm spell ? ? ?
BOSCH Fridge/Freezer - fridge wont cool....freezer fine
By andy_lanc in forum DomesticReplies: 6Last Post: 25-10-2010, 01:25 PM -
Bosch classix fridge warm freezer too cold
By journaller in forum DomesticReplies: 3Last Post: 02-11-2009, 12:51 PM -
Bosch fridge freezer - fridge strange behaviour
By Geoff75 in forum DomesticReplies: 1Last Post: 24-03-2009, 07:47 PM -
Indesit FROST FREE Fridge Freezer - fridge not cold
By pauby in forum DomesticReplies: 26Last Post: 09-03-2009, 11:04 AM -
bosch fridge freezer
By geoffishere in forum DomesticReplies: 16Last Post: 05-08-2008, 05:13 PM
