Results 1 to 9 of 9
27-04-2010, 02:43 PM #1
either Carel pCO2 or its soft has failed
Hello.
Maybe someone, by chance, have once seen such a message on the display of the controller's terminal
Internal error n.1
Atom n. 378
Offset 15772
Contact Carel
What to blame ?
28-04-2010, 08:53 AM #2
Re: either Carel pCO2 or its soft has failed
You probably tried to program it with 1Tool
28-04-2010, 09:54 AM #3
Incompatibility between BIOS, BOOT and SOFTWARE?
28-04-2010, 05:51 PM #4
I cannot work with 1-tool.
Through WinLoad I have tried to renew the bios (3.84 instead of 3.36), it refused to get uploaded without an application, so I attached the copy saved of the application, pressed "upload" : in a minute the whole thing "aborted", all communication with the controller stopped, the three leds are now constantly on meaining
application with error or no pLAN table.
That application is killed is clear, but how to return the table?
The 3-wire converter was used, through the pLan interface.
A bit of nightmare.
28-04-2010, 05:55 PM #5
Probable incompatibility between boot and bios. I'm afraid it's frozen dead. Return to Carel for reset
28-04-2010, 06:03 PM #6
No way to reestablish the communication with the controller ("defrost" it)?
29-04-2010, 06:47 AM #7
Our engineers could try and help you, but this costs...
29-04-2010, 05:32 PM #8
29-04-2010, 06:02 PM #9
I was saying in this way cause as I see we are from the neighbour countries with the author, so it could cost him some pizzas or like that
Cutler Hammer Soft Starter
By iceman007 in forum ElectricalReplies: 11Last Post: 26-05-2010, 04:56 AM -
Carel / Zanotti setup sheet required
By Andy W in forum CommercialReplies: 2Last Post: 05-03-2010, 12:07 PM -
Carel electronics - reliability?
By desA in forum ElectricalReplies: 24Last Post: 04-12-2009, 01:35 PM -
carel controller hidden reset button
By 123-steve909 in forum CommercialReplies: 1Last Post: 01-06-2009, 09:54 PM -
Hard start, Soft Start, Inverter???
By tkc100 in forum FundamentalsReplies: 9Last Post: 28-07-2007, 09:47 PM
