Thread: Bad smell from indoor unit
27-04-2010, 01:43 PM #1
Daikin VRV III ,Indoor unit Model - FXFQ100PVE. Some times there is very bad smell comes from indoor unit & that time indoor unit make abnormal sound.(Bad smell not found continous).
please suggest the solution.
27-04-2010, 05:19 PM #2
Re: Bad smell from indoor unit
disinfect evap coil, clean drains wash filters, check condensate pump
Basically give it a good service if all else fails
BRING OUT THE SMELLY JELLY
28-04-2010, 10:06 PM #3
how long has the unit been installed?
what kind of environment is it installed in?
29-04-2010, 07:28 AM #4
Hello brunstar,unit is installed & commissioned before one year. & unit is in closed room 216 sq feet
29-04-2010, 08:24 AM #5
After a real good clean as james mensioned above chuck in a biocide tablet in drain tray (you may have to break it into smaller pieces) it will help kill the bugs if they are causing smell.
Indoor coil smell solution?
By lolcakes in forum Air ConditioningReplies: 25Last Post: 09-04-2010, 12:11 AM -
gas smell not sure if its refigerent
By comet240 in forum RefrigerantsReplies: 3Last Post: 10-11-2009, 02:11 PM -
Freezer not cooling, chemical smell
By annetteh in forum Trouble ShootingReplies: 4Last Post: 01-09-2009, 01:02 PM -
Help...zanussi zert2170 stopped working & 'chemically' smell in freezer
By princeisgod in forum Trouble ShootingReplies: 3Last Post: 28-04-2009, 06:06 PM
