27-04-2010, 09:15 AM #1
variable speed drive for receprocating airconditionear
Is it possible to fit a variable speed drive to a airconditioner having receprocating compressor and will it save power consumption.
27-04-2010, 09:38 AM #2
Re: variable speed drive for receprocating airconditionear
it is possible but u have to be careful,
danfoss have a special program built in for this ,your major problem is lubrication.
basicly if it wasnt designd to be an inverter type ac i wouldnt touch it .THE DEFINITION OF A SMART PERSON IS ONE WHOM LEARNS FROM HIS MISTAKES!!!
28-04-2010, 03:36 PM #3
it seems if you are just retrofitting a standard A/C with a VFD you would run into capacity and settings issues with your TxV as well... most of the inverter units uses EEV's so they can adjust for the reduced compressor capacity in the computer program...
-Christopher
can a rotary compressor airconditionear be fitted with variable speed drive
By chintan in forum Technical DiscussionsReplies: 0Last Post: 27-04-2010, 09:00 AM -
Energy efficiency of air-source heat pumps with variable speed compressors
By BoardMan in forum FundamentalsReplies: 14Last Post: 27-01-2010, 02:32 AM -
LG heat pump problem
By back2space in forum Heat PumpsReplies: 132Last Post: 01-02-2009, 11:23 PM -
Variable Frequency Drive
By Samarjit Sen in forum Technical DiscussionsReplies: 13Last Post: 31-10-2007, 09:11 PM -
Variable speed screw compressors
By Friobernal in forum Industrial CompressorsReplies: 1Last Post: 14-11-2004, 09:28 AM
