Thread: York YS screw chiller
27-04-2010, 12:48 AM #1
Hi guys new to the forum any help would be great. I recently was working on this York chiller customer wanted to change oil and filters. My question being what is the best method of pumping chiller down? there is a service valve on the discharge line after oil sep but no service on suction, so that eliminates valving off that small section reclaiming and changing oil. I have seen on here about using your reclaimer and reclaim cylinder to transfer oil to cylinder and vapor back to chiller, but i am concerned with air getting into system with this method and pumping against pressure. There is a liquid line valve but I am not sure what LP switch opens and I am not even sure if you can get machine down to 0 any suggestions would be appreicated
27-04-2010, 04:25 AM #2
Re: York YS screw chiller
want to evacuate to 0 the machine? to change oil filters, oil and dehydrated just need to close the valves,
05-05-2010, 10:21 AM #3
u don't need to pump down, just drain the oil from oil separator and close the valve to change the filter
York Millenium Screw Chiller Code
By wint100 in forum Industrial CompressorsReplies: 8Last Post: 06-02-2011, 09:05 PM -
By iceman007 in forum Industrial CompressorsReplies: 26Last Post: 15-01-2011, 11:56 PM -
york millenuim screw chiller
By kcuk in forum Air ConditioningReplies: 1Last Post: 18-03-2010, 02:18 PM -
York Screw Chiller How low will it go?????
By bruceboldy in forum Industrial CompressorsReplies: 11Last Post: 10-08-2007, 10:29 PM -
York Open Drive Screw Chiller
By Cofreth in forum Air ConditioningReplies: 4Last Post: 24-10-2005, 02:17 PM
