Results 1 to 10 of 10
Thread: Fusible Plug
    Sittard's Avatar
    Sittard Guest
    Fusible Plug
    Hello All
    Does anybody know why some of the liquid receivers in small condening units have fusible plug when others haven't. Basically I would like to know if I have to fit one of this plug somewhere to the high pressure line when it is not built in to the liquid receiver? Do you know whch one of the eurpean norm regulates that matter?
    Many Thanks,
    Sittard
    Oct 2008
    mallorca, spain,
    75
    768
    Re: Fusible Plug
    the fusable plug is there to melt if the condencer overheats, but if its got a h-p switch set correctly, there should be no probs, if there where not a h-p switch you could have problems
    Sittard's Avatar
    Sittard Guest
    Re: Fusible Plug
    Quote Originally Posted by sedgy View Post
    In that case do you know at which temperature it starts to melt?
    Thanks,
    Sittard
    hoyle's Avatar
    hoyle Guest
    Re: Fusible Plug
    It depends on the refrigerant most of the time it is stamped on the side of the plug.
    11,025
    Re: Fusible Plug
    Oct 2008
    mallorca, spain,
    75
    768
    Re: Fusible Plug
    hey up ths SITE MADAM IS HERE
    MIND UR SPELLING , SHES WATCHING
    Auckland
    74
    3,357
    37
    Re: Fusible Plug
    Fusible plugs are an attempt to protect vessel in the event of a fire approximate to vessel. They have the occassional problem of letting go with age for no apparent reason.
    They can and will kill you if you are in the way. A bit like being hit with a hollow nose magnum bullet, messy and deadly.
    Have seen the result of one going off, large hole in roof.
    They should be outlawed.
    Oct 2006
    1,843
    21
    Re: Fusible Plug
    They also fail due to persistant long term overheating,
    either through blocked condenser or extreme ambient conditions.
    I thought that due to new regulations system now
    are not allowed to have fusable plugs?? The only way now to safely vent
    excess refrigerant pressure is through a pressure relief valve?
    Some older systems and some systems not conforming to new standards
    will still have the plug fitted.
    They tend to melt at either 90 deg c or 110 deg c if I remember correctly?
    Cheers taz
    Sinomas's Avatar
    Sinomas Guest
    Thumbs up Re: Fusible Plug
    From my point of view, fusible plug is still one of the most popular and reliable means of protections.
    Nothing will last for ever. To be sure, you need to change the fusible plug after 12 to 18 months of service.
    I say this as a manufacturer of fusible plug. It is your decision whether and how to do it.
    Aug 2007
    Sydney
    52
    1,083
    23
    Re: Fusible Plug
    In Aus and NZ fusible plugs are illegal. Only pressure relief valves are allowed. They used to be common in days of yore - Due to their unreliable operation especially as a safety device
  1. fusible plug on absorption cooling unit
    By Marco Jiang in forum Technical Discussions
    Last Post: 03-07-2010, 08:48 AM
  2. Replies: 9
    Last Post: 16-02-2010, 06:05 PM
  3. Drain plug fittings
    By spimps in forum Air Conditioning
    Last Post: 11-12-2009, 05:05 PM
  4. Samsung Power Plug doesnt fit
    By RABC in forum Trouble Shooting
    Last Post: 27-07-2007, 07:32 PM
  5. Fusible plugs?
    By monkey spanners in forum Commercial
    Last Post: 02-12-2006, 06:51 PM
