Thread: Hall v127 compressor
26-04-2010, 08:04 PM #1
Hi guys i need info on v127 compressor e, g operator instructions and maintanance teardown manual . thankyou would be grateful
29-04-2010, 05:52 PM #2
Re: Hall v127 compressor
hi ghaz
had a 1 in paper form
will look thru my history
regards
alan
29-04-2010, 08:32 PM #3
thankyou alan ,its very old compressor and its built like a tank, but it has few things on it which i don,t understand ,1 near the external oil filter it has two valves which go into the crankcase, 2 at the bottom of the oil pump bearing housing it has a valve going into the crankcase , and below the suction strainers it has two small rod like pins sticking out
05-05-2010, 07:05 AM #4
Hi GHAZ
I have a manual but not electronically.
I have had a look and I think the answers to your questions are
1 These are probably for the oil cooler in the crankcase, it is a finned coil and is refrigerant cooled. If it is being used there should be a TX valve on the side of the compressor. 2 The valve could be the oil return pressure gauge and the the pins are the capacity reduction indicating spindle. From what I can gather the pins go in and out depending on whether the cyls are loaded.
Hope this helps
Paul
MP66 & Compressor Overheating
By Intermez in forum Technical DiscussionsReplies: 111Last Post: 13-04-2010, 08:58 PM -
service manual for Hall HSS3200 compressor
By Entropie in forum Trouble ShootingReplies: 0Last Post: 26-05-2009, 04:51 PM -
Lighting's affect on compressor load
By TeamESI in forum Tools and CalculatorsReplies: 0Last Post: 14-05-2009, 06:26 PM -
[Autocascade] Only a project ATM
By before in forum CPU OverclockersReplies: 1Last Post: 07-05-2009, 11:13 AM -
Compressor Capacity
By engrkate in forum FundamentalsReplies: 15Last Post: 13-10-2006, 12:11 AM
