    495
    21
    Hall v127 compressor
    Hi guys i need info on v127 compressor e, g operator instructions and maintanance teardown manual . thankyou would be grateful
    Sep 2008
    Newcastle upon tyne
    75
    80
    Re: Hall v127 compressor
    hi ghaz
    had a 1 in paper form
    will look thru my history
    regards
    alan
    495
    21
    thankyou alan ,its very old compressor and its built like a tank, but it has few things on it which i don,t understand ,1 near the external oil filter it has two valves which go into the crankcase, 2 at the bottom of the oil pump bearing housing it has a valve going into the crankcase , and below the suction strainers it has two small rod like pins sticking out
    Aug 2007
    Adelaide Australia
    70
    562
    Hi GHAZ
    I have a manual but not electronically.
    I have had a look and I think the answers to your questions are
    1 These are probably for the oil cooler in the crankcase, it is a finned coil and is refrigerant cooled. If it is being used there should be a TX valve on the side of the compressor. 2 The valve could be the oil return pressure gauge and the the pins are the capacity reduction indicating spindle. From what I can gather the pins go in and out depending on whether the cyls are loaded.
    Hope this helps
    Paul
  1. MP66 & Compressor Overheating
    By Intermez in forum Technical Discussions
    Last Post: 13-04-2010, 08:58 PM
  2. service manual for Hall HSS3200 compressor
    By Entropie in forum Trouble Shooting
    Last Post: 26-05-2009, 04:51 PM
  3. Lighting's affect on compressor load
    By TeamESI in forum Tools and Calculators
    Last Post: 14-05-2009, 06:26 PM
  4. [Autocascade] Only a project ATM
    By before in forum CPU Overclockers
    Last Post: 07-05-2009, 11:13 AM
  5. Compressor Capacity
    By engrkate in forum Fundamentals
    Last Post: 13-10-2006, 12:11 AM
