    Apr 2010
    russia
    York YCIV0770SE Oil change
    Is chiller YORK YCIV0770SE. It is necessary to replace oil. In a separator it is shown in the bottom glass. Tried to merge under pressure, only a few litres merge. How to merge all volume of oil? What technology?
    Dec 2009
    Spain
    45
    229
    15
    Re: York YCIV0770SE Oil change
    The best solution is to clean the whole circuit out of oil, 100%. We produce the only cleaning system for any RAC system, using halocarbon technologies.
    If you want to retrofit to HFC and POE, here you can find some info about. It refers to European Regulations, but the method is applicable in Russia also
    www.fri3oilsystem.com/june.zip
    Jul 2007
    singapore
    oil must be bottom sight glass full and top must be a BIT at full HZ
  1. York Chiller problems
    By ingherrera in forum Commercial
    Last Post: 26-07-2011, 03:10 PM
  2. York Screw Model YCASO330
    By James K. Donell in forum Technical Speculations
    Last Post: 12-06-2010, 11:24 PM
  3. Basics or is it?
    By Fett in forum Fundamentals
    Last Post: 10-09-2009, 01:45 AM
  4. York Chiller OA Lockout temp adjustment ISN
    By ChasChas in forum Trouble Shooting
    Last Post: 14-05-2009, 03:46 PM
  5. York Recip NH3 Compressor Info
    By CIR391 in forum Industrial Compressors
    Last Post: 05-05-2009, 11:51 AM
