Thread: York YCIV0770SE Oil change
26-04-2010, 01:35 PM #1
Is chiller YORK YCIV0770SE. It is necessary to replace oil. In a separator it is shown in the bottom glass. Tried to merge under pressure, only a few litres merge. How to merge all volume of oil? What technology?
27-04-2010, 10:21 AM #2
Re: York YCIV0770SE Oil change
The best solution is to clean the whole circuit out of oil, 100%. We produce the only cleaning system for any RAC system, using halocarbon technologies.
If you want to retrofit to HFC and POE, here you can find some info about. It refers to European Regulations, but the method is applicable in Russia also
www.fri3oilsystem.com/june.zip
01-08-2011, 02:07 PM #3
oil must be bottom sight glass full and top must be a BIT at full HZ
York Chiller problems
By ingherrera in forum CommercialReplies: 18Last Post: 26-07-2011, 03:10 PM -
York Screw Model YCASO330
By James K. Donell in forum Technical SpeculationsReplies: 1Last Post: 12-06-2010, 11:24 PM -
Basics or is it?
By Fett in forum FundamentalsReplies: 17Last Post: 10-09-2009, 01:45 AM -
York Chiller OA Lockout temp adjustment ISN
By ChasChas in forum Trouble ShootingReplies: 1Last Post: 14-05-2009, 03:46 PM -
York Recip NH3 Compressor Info
By CIR391 in forum Industrial CompressorsReplies: 1Last Post: 05-05-2009, 11:51 AM
