    Feb 2010
    Brisbane
    21
    Heat pump-cooling and heating capacity and capacity of compressor
    hi everybody,
    can you tell me if compressor capacity is measuring and compare to a heating capacity of heat pump or cooling capacity of heat pump?
    if cooling capacity is 7.5 kw,and heating capacity is 8.4 kw,what should be compressor capacity of heat pump,for example when ordering new compressor to be replaced?
    11,025
    Re: Heat pump-cooling and heating capacity and capacity of compressor
    Order the compressor to match that which is being replaced.
    Oct 2003
    5,630
    34
    Swept volume must be the same
    Apr 2010
    Australia
    11
    it will be rated to the cooling capacity, as the heating capacity is generally higher due to the extra heat produced mechanically during the compressors operation(friction/heat of compression etc.) and with hermetic compressors also electrical heat. But as Brian stated best to go with the same as the original compressor,as long as it is designed correctly.Good luck
  1. Vrv
    By tgoonter in forum Air Conditioning
    Last Post: 11-01-2011, 06:25 AM
  2. Capacity control
    By sparrow in forum Training
    Last Post: 18-01-2010, 07:49 PM
  3. Heat pump hot water system
    By kiamaian in forum Technical Speculations
    Last Post: 16-06-2009, 06:48 AM
  4. "Home made" 150 kW heat pump
    By SteinarN in forum Fundamentals
    Last Post: 22-03-2009, 10:07 PM
  5. LG heat pump problem
    By back2space in forum Heat Pumps
    Last Post: 01-02-2009, 11:23 PM
