    keerth1986's Avatar
    keerth1986 Guest
    air cooled condenser size calc????
    HI frns,
    Can any help me to calculate total length of an air cooled condenser required for 1 TON water chiller.
    Heat Load of chiller = 3.5kW
    Condensing temp.=50 degC , evaporating temp.=5 degC, R407C gas, condenser tube dia.=9.525mm copper tube(plain) with aluminium fins,
    secondary fluid(water) details:
    inlet water temperature=20 degC
    outlet water temp. = 15 degC
    temperature difference = 5 degC
    water flow rate =10 LPM
    Mar 2009
    KZN, South Africa
    63
    2,212
    Re: air cooled condenser size calc????
    http://www.coolit.co.za/
    You will find a number of useful software tools on this site, at very reasonable prices. I strongly endorse these products & use them myself.
    Sep 2003
    ISRAEL
    72
    4,248
    Quote Originally Posted by keerth1986 View Post
    HI frns,
    Please do as Des told you to but remember to add the compressor watts to the total heat removed.
    Oct 2003
    5,630
    34
    5,8 m is a rough estimate
    moideen's Avatar
    moideen is offline Veteran Poster I am starting to push the Mods: of RE
    Apr 2008
    u.a.e
    48
    412
    22
    Quote Originally Posted by desA View Post
    hi desa,is this free soft ware?if you belonged mollier chart software ,coul you please send me.
    Moideen-Dubai
  1. R410A water cooled condenser
    By K.R.Iyer in forum Fundamentals
    Last Post: 04-02-2009, 02:10 AM
  2. water cooled condenser
    By langy in forum Air Conditioning
    Last Post: 19-08-2008, 06:43 PM
  3. Air Cooled Condenser Leakage Problem with R-404A
    By RADHAKRISHNARAO in forum Technical Discussions
    Last Post: 30-07-2008, 12:21 PM
  4. method to design air cooled condenser
    By abbasi in forum New Technologies
    Last Post: 12-02-2008, 08:34 AM
  5. Making a simple water cooled condenser
    By The MG Pony in forum Fundamentals
    Last Post: 01-08-2007, 11:02 AM
