Results 1 to 2 of 2
    Nov 2006
    china
    48
    21
    help!thermosyphon oil cooling
    Now I am designing a propane thermosyphon oil cooling,but I don't know how to caculate the liquid line Diameter from the receiver tho the heat exchanger.According with the IR hand book.the pressure gradient for this pipe are 22.6pa/m for R22.What's the means of pressure gradient?and how to caculate the Diameter by the pressure gradient.
    Aug 2008
    California
    28
    Re: help!thermosyphon oil cooling
    The pressure gradient is the pressure drop per unit of length of pipe.
    The first step is to calculate the required flow rate required by your oil cooling requirement. Times your recirculation rate.
    Next step is to find the viscosity valves of your refrigerant.
    Next is to calculate the “head loss” of this flow rate though various pipe sizes. Choose the pipe size that has less than or equal to your desired pressure gradient.
  1. help!thermosyphon oil cooling
    By joanna in forum System Optimization
    Last Post: 28-04-2010, 04:52 AM
  2. Cooling problem with VRV REYQ24M7.
    By cool#9 in forum Air Conditioning
    Last Post: 07-02-2010, 12:20 PM
  3. Compressor loading, cooling, and range of operation.
  4. Cooling tower evaporation, blowdown, makeup and cycles
    By miltbeychok in forum Industrial
    Last Post: 14-10-2005, 06:34 PM
  5. Cooling tower evaporation, blowdown, makeup and cycles
    By miltbeychok in forum Fundamentals
    Last Post: 13-10-2005, 05:14 AM
