Thread: TCL E6 Error Code
20-04-2010, 09:51 PM #1
TCL E6 Error Code
Hi All, just wondering if anyone knows what a E6 error code on a TCL might be? The system runs fine for a few hours and then goes ou on this E6 error and shuts down.
thanks Darren
21-04-2010, 01:40 PM #2
Re: TCL E6 Error Code
Sorry I should have spelt a bit better and also put down that the model is a TAC-12CS/GM2 which is approximately 4 years old. I tried calling a melbourne number today for TCL and it was constantly enguaged and Castel who use to handle TCL for a while don't know the model or fault code.
27-04-2010, 01:52 PM #3
Anyone know an old TCL dealer in Australia and or Queenslan that I can ring and ask about the E6 fault. thanks Darren
28-04-2010, 08:36 AM #4
Castel australia
Try Here- http://www.castel.com.au/tcl/
05-05-2010, 12:46 PM #5
thanks aucooler they were no help as it is a unit that was prior to them taking on TCL. I was up there again today and it was out on E6 again so I have checked everything from the gas charge, sensors and also that it was on cooling. problem is it runs fine on heating and cooling and it will run for over 2 hours before the E6 error shows. I will even try to email TCL New Zealand tonight and see if they can help. I did suggest jut replacing the unit with a quality unit but they won't as the unit will be removed in approximately 10 to 18 months as the property is being demolished. Nomally I would change it or fix it if the customer is broke thanks Darren
06-05-2010, 05:12 AM #6
Simply Cool.
E6 error is indoor fan motor failure.
07-01-2011, 10:37 AM #7
07-01-2011, 02:36 PM #8
And what about compressor? Does it starts up?
07-05-2011, 09:57 AM #9
