Results 1 to 9 of 9
    Dec 2009
    47
    11
    TCL E6 Error Code
    Hi All, just wondering if anyone knows what a E6 error code on a TCL might be? The system runs fine for a few hours and then goes ou on this E6 error and shuts down.
    thanks Darren
    Dec 2009
    47
    11
    Re: TCL E6 Error Code
    Sorry I should have spelt a bit better and also put down that the model is a TAC-12CS/GM2 which is approximately 4 years old. I tried calling a melbourne number today for TCL and it was constantly enguaged and Castel who use to handle TCL for a while don't know the model or fault code.
    Dec 2009
    47
    11
    Anyone know an old TCL dealer in Australia and or Queenslan that I can ring and ask about the E6 fault. thanks Darren
    Apr 2009
    Australia
    56
    30
    Castel australia
    Try Here- http://www.castel.com.au/tcl/
    Dec 2009
    47
    11
    thanks aucooler they were no help as it is a unit that was prior to them taking on TCL. I was up there again today and it was out on E6 again so I have checked everything from the gas charge, sensors and also that it was on cooling. problem is it runs fine on heating and cooling and it will run for over 2 hours before the E6 error shows. I will even try to email TCL New Zealand tonight and see if they can help. I did suggest jut replacing the unit with a quality unit but they won't as the unit will be removed in approximately 10 to 18 months as the property is being demolished. Nomally I would change it or fix it if the customer is broke thanks Darren
    Feb 2009
    Australia
    273
    11
    Simply Cool.
    E6 error is indoor fan motor failure.
    mix_skiathos's Avatar
    mix_skiathos Guest
    Quote Originally Posted by lawrence1 View Post
    Simply Cool.
    I have E5 error in TCL model tac 50 flloor air condition
    the unit is stoped. the service manual say Outdoor unit protected i check all thermistors are ok the fan capacitor its ok .
    What can i do more ???
    Thank you.
    Sep 2010
    Kazakhstan
    36
    And what about compressor? Does it starts up?
    voigt67's Avatar
    voigt67 Guest
    Quote Originally Posted by mix_skiathos View Post
    Thank you.
    Jassu Skiathos ,the E5 code is a problem with the communication from indoor to outdoo unit .I have the same problem in my house in Greece .If you want to wright me ,please use this adress :info@haus-markos.de .
    regards from Germany
