Results 1 to 11 of 11
Thread: daikin rsey8
20-04-2010, 04:22 PM #1
daikin rsey8
The saga continues, had an e9 error(faulty eev or outdoor board), both exp. valves meter out ok so i replaced the outdoor board.
How long does self address take? I pressed reset for 5 seconds as per manual, unit not showing on dbacs after 1 hour, should i be worried?
alec
20-04-2010, 05:06 PM #2
Re: daikin rsey8
Try powering down the master unit keep reset pushed in and power back up re address should about 15 mins this works on reyq vrv3
20-04-2010, 05:44 PM #3
Re: daikin rsey8
Thanks james, i'll give it a go, only worry is that e9 is still up on indoors.
Alec
20-04-2010, 06:15 PM #4
Re: daikin rsey8
once you've powered down the outdoor unit the fault codes should dissapear
if all else fails contact Daikin Technical 01932879200
20-04-2010, 07:24 PM #5
Re: daikin rsey8
Ok, powered down indoors and outdoor, repowered indoors and reset outdoor.
Outdoor not registering on dbacs and indoors faulting on E9 again
Any ideas? Could the expansion valve board be faulty?
Thanks for the input so far....
alec
20-04-2010, 08:12 PM #6
Re: daikin rsey8
are the dip switches the same as the old pcb? not sure on the expansion valve if you have another unit the same on site it might be worth comparing the resistance of the motors and outputs from the pcb
20-04-2010, 11:32 PM #7
Re: daikin rsey8
James
No dips on this board or the old one, weird that its dropped off the dbacs.
Alec
22-04-2010, 05:21 PM #8
Re: daikin rsey8
Alex
i've been reading upon your E9 error code and found an alternative description to the daikin text description this description points directly to the expansion valve coil
22-04-2010, 08:51 PM #9
Re: daikin rsey8
Thanks james, i'll order up two valves and the expansion valve board, could be a bit of trial and error....
Thanks for the help
alec
11-05-2010, 07:39 PM #10
Re: daikin rsey8
How did you get on with the valves?
11-05-2010, 08:36 PM #11
Re: daikin rsey8
Hi James
Believe it or not i'm still waiting on the valves and the go ahead from the customer, speaking to a previous tech who serviced these units this has happened before with the same symptoms so i'm confident that the valves will fix the problem. Thanks for the help
alec
Daikin not working... many problems
By stankovicv in forum Air ConditioningReplies: 26Last Post: 11-12-2010, 09:01 AM -
Panasonic Urban rebadged Daikin
By complete HVAC in forum Air ConditioningReplies: 0Last Post: 19-08-2009, 04:35 PM -
Daikin AC parts from UK
By skel00 in forum Air ConditioningReplies: 5Last Post: 05-04-2009, 01:24 PM -
Fixing Daikin A3 Error
By Stuffy in forum Air ConditioningReplies: 3Last Post: 27-03-2009, 06:02 AM -
Getting a price from Daikin....
By monkey spanners in forum Chit Chat & Service StoriesReplies: 4Last Post: 17-08-2008, 09:46 PM
