    Nov 2006
    china
    43
    21
    help!thermosyphon oil cooling
    Now I am designing a propane thermosyphon oil cooling,but I don't know how to caculate the liquid line Diameter from the receiver tho the heat exchanger.According with the IR hand book.the pressure gradient for this pipe are 22.6pa/m for R22.What's the means of pressure gradient?and how to caculate the Diameter by the pressure gradient.
    Tran K's Avatar
    Tran K Guest
    Re: help!thermosyphon oil cooling
    Condition for selecting of line diameter:
    22.6Pa x Total Lenght < r.g.H
    Total Lenght = Reale Length of pipe + aquivalent length of valves + fittings
    r = kg/m2
    g = 9.81
    H= Level difference btw. Liquid level of thermosyphone receiver and oil cooler
    22.6Pa for R22, you choice other value for Propane.
    Tran K's Avatar
    Tran K Guest
    r = kg/m3
    g = 9.81 m/s2
  1. Cooling problem with VRV REYQ24M7.
    By cool#9 in forum Air Conditioning
    Last Post: 07-02-2010, 12:20 PM
  2. Energy saving Glycol filled dry cooler circuits
    By Jasper in forum Technical Discussions
    Last Post: 19-06-2008, 02:18 PM
  3. Compressor loading, cooling, and range of operation.
  4. Cooling tower evaporation, blowdown, makeup and cycles
    By miltbeychok in forum Industrial
    Last Post: 14-10-2005, 06:34 PM
  5. Cooling tower evaporation, blowdown, makeup and cycles
    By miltbeychok in forum Fundamentals
    Last Post: 13-10-2005, 05:14 AM
