    andrew1977's Avatar
    andrew1977 Guest
    Saving energy in the design of low-temperature chamber
    Hi guys help with whatever they can? customer set a target for the design of low-temperature chamber for Maxim with saving electric energy, I designed the electronic gate and inverter compressor, wanted to design a floor heating in the chamber with the heated glycol condensing unit but could not because the car in winter will not give such a load, like to hear what else you can do for energy savings
    May 2006
    India
    74
    399
    Re: Saving energy in the design of low-temperature chamber
    You will need heat reclaim condenser
    May 2006
    India
    74
    399
    You will need re-evaporator coil sothat you will get the required heat
    andrew1977's Avatar
    andrew1977 Guest
    how best to do if the load in the summer, one winter, the other?
  1. Design Return Gas Temperature (RGT):
    By gwapa in forum Commercial
    Last Post: 13-09-2009, 01:44 PM
  2. Optimising parallel water chillers for energy saving
    By Electrocoolman in forum System Optimization
    Last Post: 27-07-2009, 01:56 PM
  3. How to Design Refrigeration Systems
    By US Iceman in forum Fundamentals
    Last Post: 24-07-2008, 04:27 PM
  4. Building a wine cabinet
  5. Article in ACH&R News
    By Gary in forum Fundamentals
    Last Post: 20-05-2003, 12:27 AM
