19-04-2010, 11:06 AM #1
Saving energy in the design of low-temperature chamber
Hi guys help with whatever they can? customer set a target for the design of low-temperature chamber for Maxim with saving electric energy, I designed the electronic gate and inverter compressor, wanted to design a floor heating in the chamber with the heated glycol condensing unit but could not because the car in winter will not give such a load, like to hear what else you can do for energy savings
19-04-2010, 12:17 PM #2
Re: Saving energy in the design of low-temperature chamber
You will need heat reclaim condenser
19-04-2010, 12:18 PM #3
You will need re-evaporator coil sothat you will get the required heat
19-04-2010, 12:40 PM #4
how best to do if the load in the summer, one winter, the other?
Design Return Gas Temperature (RGT):
By gwapa in forum CommercialReplies: 0Last Post: 13-09-2009, 01:44 PM -
Optimising parallel water chillers for energy saving
By Electrocoolman in forum System OptimizationReplies: 7Last Post: 27-07-2009, 01:56 PM -
How to Design Refrigeration Systems
By US Iceman in forum FundamentalsReplies: 63Last Post: 24-07-2008, 04:27 PM -
Building a wine cabinet
By Rory in forum Technical DiscussionsReplies: 38Last Post: 13-07-2004, 08:28 PM -
Article in ACH&R News
By Gary in forum FundamentalsReplies: 8Last Post: 20-05-2003, 12:27 AM
