Results 1 to 2 of 2
    Apr 2010
    4
    Frick RXF30 Shaft Seal Repair
    I inhereted a pair of Frick RXF30 screw compressors using R-22 in a flooded evaporator, two-stage subcooler/accumulator type system. There are two thermosyphon type oil coolers.
    I have a compressor with oil and refrigerant blowing out of the oil drainage bottle when the plant isn't running. The hours on this compressor is 482103. Maintenance on this system has been a joke: Keep adding factory oil to one cirduit which always runs low and thats about it.
    I'm looking for service literature on shaft seal repair and other repairs on this system (filters, thermostatic oil valves, etc). Anyone out there with info?
    Auckland
    74
    3,357
    37
    Re: Frick RXF30 Shaft Seal Repair
    Hazard a guess that the shaft seal is stuffed, suggest that screws be removed and fully stripped and repaired, start with a shaft seal kit if client is broke, and add a Laser alignment as well to clear any issues.
    magoo
  1. shaft seal failure
    By modvalve in forum Industrial Compressors
    Last Post: 01-04-2010, 06:02 PM
  2. Carrier Twin-port O5G - wet shaft seal?
    By carrier_trained in forum Transport
    Last Post: 26-03-2010, 09:08 AM
  3. Frick 193 shaft seal
    By NH3ISFORME in forum NH3
    Last Post: 14-03-2010, 09:35 PM
  4. Mechanical Shaft seal
    By amir.h in forum Technical Discussions
    Last Post: 23-12-2009, 02:52 PM
  5. Frick shaft seal leaking
    By Ian B in forum Industrial Compressors
    Last Post: 27-01-2009, 10:31 PM
