Thread: Bus a/c
    Mar 2010
    greece
    47
    Bus a/c
    hallo everyone
    i work on a city bus with one compressor BOCK FK40 and 2 units.the problem is how the first unit have almost cold air and the other only air.but the pressure is normal.
    thanks
    11,025
    Re: Bus a/c
    Is the pressure normal at both units?
    May 2006
    India
    74
    399
    Re: Bus a/c
    The other unit is possibly not getting the refrigerant , solenoid not switched on etc .
    Mar 2010
    greece
    47
    Re: Bus a/c
    yes it is the same compressor for bouth units.the pressure is 30psi low and 190psi high.R134a.filters ok expension valves ok oil ok.i dont know what .
    Mar 2010
    greece
    47
    Re: Bus a/c
    i see the refrigerant from the glass eye and is full up.
    11,025
    Re: Bus a/c
    But what are the two evaporators doing?
    Mar 2010
    greece
    47
    Re: Bus a/c
    the first evaporator near to compressor is cold but not good and the other nothing.only air
