Thread: Bus a/c
18-04-2010, 12:13 AM #1
Bus a/c
hallo everyone
i work on a city bus with one compressor BOCK FK40 and 2 units.the problem is how the first unit have almost cold air and the other only air.but the pressure is normal.
thanks
18-04-2010, 11:41 PM #2
Re: Bus a/c
Is the pressure normal at both units?
19-04-2010, 12:10 PM #3
Re: Bus a/c
The other unit is possibly not getting the refrigerant , solenoid not switched on etc .
19-04-2010, 06:04 PM #4
Re: Bus a/c
yes it is the same compressor for bouth units.the pressure is 30psi low and 190psi high.R134a.filters ok expension valves ok oil ok.i dont know what .
19-04-2010, 06:06 PM #5
Re: Bus a/c
i see the refrigerant from the glass eye and is full up.
19-04-2010, 08:30 PM #6
Re: Bus a/c
But what are the two evaporators doing?
19-04-2010, 10:42 PM #7
Re: Bus a/c
the first evaporator near to compressor is cold but not good and the other nothing.only air
