Thread: inverter problem
17-04-2010, 06:56 AM #1
inverter problem
can i ask, why during defrosting process of the ice cream display, the ice inside of evaporator doe'snt melt,, and the filter drier and also the liquid reciever was getting ice,. what should be the problem of thus senario? it is because of hot gas from the inverter or the filter drier was block??? plss reply
17-04-2010, 08:39 PM #2
Re: inverter problem
drier choked,do you mean compressor instead of inverter?
19-04-2010, 06:20 AM #3
I think the hot gas from the inverter inverted the hot gas into cold gas, that's why it's called an inverter.
That's why your filter became ice (it's normal hot)It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
MFI AMP6855 defrost problem
By gliderpilot47 in forum DomesticReplies: 4Last Post: 12-01-2011, 12:11 PM -
Problem about Inverter and Compressor
By steven86 in forum FundamentalsReplies: 3Last Post: 21-02-2010, 03:01 PM -
Problem with a Hiyasu Inverter HOW-12LA
By Debonair Spain in forum Air ConditioningReplies: 8Last Post: 06-01-2010, 09:52 AM -
problem with GE air con power problem
By Richie101 in forum Air ConditioningReplies: 6Last Post: 05-11-2009, 04:00 PM -
Panasonic wall split inverter problem
By mattarooni in forum Air ConditioningReplies: 3Last Post: 02-12-2008, 05:32 AM
