Thread: Service Bulletin Quiry
13-03-2005, 05:33 PM #1
Hi Guys,
I recieved a couple of weeks ago a service bulletin which no doubt some of you will have seen. It relates to the positioning of a TEV and say's that they can maulfunction if not vertical. Now as far as i am aware TEV's are operated using pressure against an internal spring so what difference does it's location make. Here is the Bullentin apart from the manufacturer blanked out.
Problem:-
######## is now aware that a small number of these units were manufactured with the TEV Valve in a horizontal attitude. This may result in the vale operating in a partially closed manner. This will cause the evap and the TEV to become iced up.
Solution:-
The TEV needs to be orientated so the head is above the body, and the valve should be made as vertical as possible.
Any Comments
Fatboy
13-03-2005, 05:56 PM #2
Re: Service Bulletin Quiry
Hi Raymond,
I have raised the subject a while ago and with the help of Prof. Sporlan , the conclusions was the same.
But..... other opinions and experience will be most welcome.
Chemi
13-03-2005, 10:31 PM #3
My first thought would be with oil/liquid accumulating around one (lower) of the guide pins and slowing/blocking the valve action; but what do I know
15-03-2005, 03:49 PM #4
Originally Posted by Brian_UK
Sorry again for hijacking the thread.
Cheers John
16-03-2005, 05:57 AM #5
Chemi, where is the tread between you and prof Sporlan?
16-03-2005, 03:14 PM #6
Hi Peter,
There is not much there but here it is:
http://www.refrigeration-engineer.co...ead.php?t=1129
Chemi
16-03-2005, 10:44 PM #7
Originally Posted by BulldogBrian - Newton Abbot, Devon, UK
Service Contracts
By frank in forum Air ConditioningReplies: 14Last Post: 03-06-2010, 10:06 AM -
Day Rate?
By Andy T in forum Legal-Business-MarketingReplies: 17Last Post: 02-06-2010, 11:38 PM -
New to self employed
By priory in forum Legal-Business-MarketingReplies: 13Last Post: 07-02-2005, 06:26 AM -
Service contracts
By iceman007 in forum Legal-Business-MarketingReplies: 8Last Post: 23-08-2004, 04:38 PM
