    Jan 2010
    north wales
    Question electolux commercial
    how do? ive been having difficulty gleaning tech info from lux technical, very cagey indeed. can you knowledgeable chaps and chapesess help? its a 2 door commercial lux freezer. split evap with fan inbetween. electric defrost, mech timer. are there supposed to be 2 defrost term klixons on the coil (1 on each half of evap) or not? also could anyone point me in the direction of a wiring diagram for said cabinet? any help would be greafully received.ta.
    Apr 2010
    295
    15
    Re: electolux commercial
    hi dig i used to do lux warranty work an i dont think they have tech support lol lux need all the cab numbers or they wont or cant tell you any thing and i think there was only one cut out on them not 100per cent sure top tip pull the electrolux badge logo on the front off all the numbers you need are under there oh and if you ever see the same cab with a zannusi badge on it is same cab same probs as well hope this helps some
    Dec 2004
    Scotland
    42
    106
    Who does the spares for LUX??
    scotland
    756
    Quote Originally Posted by craigpcg View Post
    electrolux do the spares, however if you dont have every bit of info regards the part you need they wont help a bit
    Dec 2004
    Scotland
    42
    106
    Buggers thanks :thumbs:
    Apr 2010
    295
    15
    also code set on controller is 11 the elliwell controllers hope this helps
    scotland
    756
    suppliers of electrolux parts as follows
    1: cr parts 01784 457709
    2:electrolux 0121 623 1818
    3: nothern refrigeration 0870 872 6360
    all of the above do spares for electrolux cases.
  1. Occasional use commercial ice machine
    By Catmandu in forum Commercial
    Last Post: 19-01-2010, 04:54 AM
  2. Commercial Refrigerator Vs. Commercial Cooler
    By mikefitz in forum Technical Discussions
    Last Post: 04-05-2007, 03:38 PM
  3. Scotsman commercial H2O inlet valve
    By fullcourt in forum Trouble Shooting
    Last Post: 25-04-2006, 11:41 PM
  4. Commercial
    By David PS in forum Industrial
    Last Post: 10-03-2005, 08:48 PM
