Results 1 to 2 of 2
14-04-2010, 06:20 AM #1
Electricity consumption during hot gas defrosting
My friend owns a 8Kw(A7/W35) outdoor air/water heat pump,he wants to know the power consumption of the heat pump during 3 mins hot gas defrosting.How to calculate it?
Any comments would be highly appreciated.
14-04-2010, 08:16 AM #2
Re: Electricity consumption during hot gas defrosting
Hi ginger jiang
Measure the current draw of the unit durring the 3 minute defrost and measure the voltage. Multiply the voltage by the current then multiply by the power factor, this gives power. Power = Watts, Watts = Juole/Second. Multiply Watts by 1000 to get kiloWatts.
For consumption (i think this is right) you need kWh kiloWatt hours. If the unit uses 2 kW for the whole hour it would use 2 kWhs. So divide your calculated kiloWatts by 3600 (1 hour / 60 mins / 60 secs) then muliply by 3 (mins) then multiply by 60 (secs). This will give you kWh consumption per 3 minute defrost cycle.
Power consumption of Chiller
By adrian116 in forum System OptimizationReplies: 7Last Post: 24-04-2009, 05:05 PM -
Thawing Room (defrosting Room For Meat)
By arunuae in forum CommercialReplies: 3Last Post: 09-02-2008, 09:24 AM -
electricity consumption of refrigerator
By junhonguk in forum Trouble ShootingReplies: 9Last Post: 11-01-2008, 01:41 AM -
Electricity consumption porblem
By Alberto R.J. in forum ElectricalReplies: 4Last Post: 24-07-2007, 09:24 PM
