    Nov 2006
    Middle East (United Arab Emirates)
    43
    Question Remote fitted condensing unit
    Hi Everyone.
    If the condensing unit of a refrigeration system is remote fitted, how is it accounted in component selection?. For example a walk-in cold room with heat load of, say 4000 BTUH, has to be constructed either with the condensing unit attached to it or the unit 10 m (32.8 ft) away. If the condensing unit is away will it use the same condensing unit as that of the first case? Or how is it selected.
    Thanks in advance
    With regards
    Rayin
    Oct 2005
    IRAN
    878
    Re: Remote fitted condensing unit
    Hi there,
    The distance between components is used to size the pipes. With the correct length of the pipes and its fittings the pipe size must be calculated for pressure drop and oil return to the compressor.
    Even Einstein Asked Questions
    Oct 2003
    5,630
    34
    The size of the condenser will not change unless you have much higher or lower temperatures outside than inside.
    Split Croatia
    57
    6,151
    36
    As previous posters already said, size is not dependent on distance, it depend on conditions of air which is around condenser.
    If your condenser is designed for indoor usage with temperatures from 10°C to 30°C it cannot be used for outdoor where temperatures are from -5°C to 45°C or more.
    Nov 2006
    43
    Hi..Lana, Peter_1 and Nike,
    Thank you for your prompt response. So from your rplies what I understand is, as far as ambient air condition is not changed, no need to change the condensing unit, for a remote fitted unit. Only thing the pipe line sould be sized in such a way that the total pressure loss should be in the permissible limit of design conditions. Am I correct?
    Rayin
    Oct 2003
    5,630
    34
    Indeed Rayin, just calculate your lines, that's all.
    Nov 2006
    43
    Dear Peter_1,
    It is clear now. Thank you very much indeed.
    Rayin
  1. DX capacity lower than condensing unit
    By M.Saleh in forum Air Conditioning
    Last Post: 18-01-2010, 03:01 AM
  2. Sizing a condensing unit for a serve over counter
    By jimbo22 in forum Fundamentals
    Last Post: 25-11-2009, 04:50 PM
  3. Thermo King OptiSet
    By REEFER-TEK in forum Transport
    Last Post: 06-12-2007, 07:23 PM
  4. York/Bristol Condensing Unit
    By Abe in forum Commercial
    Last Post: 03-02-2003, 07:46 PM
  5. Matching Evaporator with Condensing Unit
    By Abe in forum Technical Discussions
    Last Post: 25-07-2001, 08:57 AM
