Thread: Fridge compressor oil
14-04-2010, 12:47 AM #1
Hi. I got GE SxS 27cf with 1/4 Hp compressor, 1007 BTU, model: DA86C15RBU6 Matsu****a compressor. I am trying to figure out how much oil should be in the system. I drained some out and going to blow out the rest from piping on the fridge. Is there any guide for each compressor how much oil should be in it, like when factory fills it? I want to compare the original amount to what should be in it. Thanks all.
14-04-2010, 09:54 PM #2
Re: Fridge compressor oil
Why did you drain the oil from the compressor, for what reason?
15-04-2010, 08:05 PM #3
15-04-2010, 11:08 PM #4
03-05-2010, 03:42 AM #5
Apparently the sealed system had problem so it had to be opened.
It was opened for some time so naturally the oil is going to have some moisture in it. So my question still remains the same and unanswered: Can some one tell me please if there is any oil guide for compressors and how much should be in it? My fridge/compressor doesn't describe the amount of oil. Thanks.
04-05-2010, 01:51 AM #6
250ml
Freol 22 or equal polyolester 22
07-05-2010, 11:01 PM #7
Thanks so much Lawrence1.
Hotpoint Mistral Plus - Fridge Freezer
By cozzie121 in forum DomesticReplies: 9Last Post: 19-09-2010, 08:45 AM -
extending temp range of domestic fridge
By kubcat in forum DomesticReplies: 1Last Post: 06-01-2010, 04:21 PM -
UK - Fridge/freezer, fridge warm - needs replacing??
By ken300 in forum DomesticReplies: 5Last Post: 04-11-2009, 07:21 AM -
Indesit FROST FREE Fridge Freezer - fridge not cold
By pauby in forum DomesticReplies: 26Last Post: 09-03-2009, 11:04 AM -
is my fridge working properly?
By vincec in forum Trouble ShootingReplies: 1Last Post: 15-01-2002, 09:55 PM
