Thread: carpigiani HOT adjustment?
13-04-2010, 09:58 PM #1
Hello new to this forum but looking for a little help.I am attempting to set up a soft serve for a customer and the ice cream is to soft. The manual states to adjust the HOT setting any idea where this adjustment is and the protocol to setting it? thanks in advance
28-06-2010, 12:41 PM #2
Re: carpigiani HOT adjustment?
special button activation needed for all setponts
28-06-2010, 11:08 PM #3
One machine I looked at a long, long time ago had a manual adjustment know on the unit front.
29-06-2010, 04:11 AM #4
The soft delivery of icecream usually means the torque setting to control the drive motor is too light. They have a PC board in control panel that is adjustable. Cannot recall which one is to be adjusted.
Check with the Capo.. web site and down load service info for your particular machine.
the other thing to check is that the client is using the correct softserve pre-mix. Has to have all the correct ingredients to work and serve product, pre-chilled etc, over night.
magoo
06-09-2010, 10:08 AM #5
Please let me know the machine model then i can let you know how to access and adjust. Many Thanks.
12-10-2010, 11:53 AM #6
Hi it is for 191/g/p and 161g/p press and hold the stop and the (>>) button for three sec and release when start flashing. Mow you can use the (>>) button to adjust the consistency between 1-10
I hope this helps
carpigiani ice cream van
By DAMIAN SIMI in forum Trouble ShootingReplies: 2Last Post: 10-05-2010, 03:25 AM -
carpigiani ice cream machine temp settings
By superwhippy in forum Trouble ShootingReplies: 8Last Post: 04-05-2010, 08:23 PM -
Carpigiani 181 never stops running...?!
By Jepson75 in forum Trouble ShootingReplies: 3Last Post: 11-08-2009, 08:00 PM -
Liguid Injection Temperature Adjustment
By NH3LVR in forum Industrial CompressorsReplies: 4Last Post: 06-12-2006, 04:41 PM
