Results 1 to 8 of 8
Thread: General Fault...again.
12-04-2010, 04:52 PM #1
Just been to look at General unit (ABG24RBA, I think). As soon as the unit is powered up it goes straight in to fault.
Operation (red) flashes 2 times
Timer (Green) Flashes rapidly
Vertical Swing (Orange) Flashes rapidly
Horizontal Swing is off all the time.
I donīt have any manuals or codes or anything for this unit, but I think that is Room Thermistor Fault, am I right?
cheers,
paul..
12-04-2010, 09:47 PM #2
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: General Fault...again.
Check your model #!
12-04-2010, 09:59 PM #3
The data plate is pretty mashed up and hard to read. Itīs a floor/ceiling unit on R22 I think. It might be ABG24RBA-W, is that any closer?
13-04-2010, 12:29 AM #4
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Yep it is probably room thermistor error. It should be 10kOhm at 25°C.
13-04-2010, 04:13 PM #5
thanks Nike, is that model nš correct?
13-04-2010, 04:28 PM #6
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
13-04-2010, 05:17 PM #7
That sounds right, many thanks.
17-06-2010, 04:50 PM #8
I know this is quite an old thread but I have just been to do this job. Swapped the sensor over, powered up and and the unit started. Switched the power off and back on again and then unit now goes in to pipe thermistor fault before the outdoor even starts.
I think it is a dead PCB as the client didn't tell me before, but if they turned the power off to the unit, when turned back on it would sometimes (1 out of 10 times) work until the power went off again, at which point it would show the room thermistor fault. So it seems to be an intermittent fault, hence why I think indoor PCB.
Any thoughts?
Supra common fault - usually misdiagnosed.
By carrier_trained in forum TransportReplies: 3Last Post: 15-04-2010, 08:56 PM -
Daikin Split f3 Fault
By moondawn in forum Air ConditioningReplies: 18Last Post: 01-06-2009, 07:09 PM -
Fault with Tango cassette
By airefresco in forum Air ConditioningReplies: 8Last Post: 19-09-2007, 08:42 AM -
UA Daikin Fault Code
By jedi in forum Air ConditioningReplies: 2Last Post: 23-07-2007, 01:44 PM -
u4 fault on a Daikin inverter
By phil17 in forum Air ConditioningReplies: 39Last Post: 05-02-2007, 02:41 AM
