    Apr 2010
    china
    Question hot water outlet position in water tank?
    I find the hot water outlet is alway in the upper of water tank while cold water inlet in the lower. why?
    I am just involved in air source heat pump industry, pls kindly help me out with this question. And any friend can suggest some web or info. of learning air source heat pump. Many thanks!!
    Have a good day.
    11,024
    Re: hot water outlet position in water tank?
    Quote Originally Posted by billliu2010 View Post
    Study convection.
    Try manufacturer's websites.
    Apr 2009
    israel
    778
    Have a good day.
    Hi simple physics,heat rises cold drops!!
    ask dr google about hetpumps and u will have plenty of info.
    THE DEFINITION OF A SMART PERSON IS ONE WHOM LEARNS FROM HIS MISTAKES!!!
    Aug 2007
    Sydney
    52
    1,083
    23
    Not too much info about tis on web. Try thermosyphon effect, basicly hot water rises in the centre and to the top (when colder outside). Also check out paper capacitor for design geometrics, then maxima/minaima calculus give about 1 x dia to 2 height (for a cylender). Now that's given all the secrets away - good luck and let us know how you go.
    Apr 2010
    china
    Many thanks for the answer of three friends! With your help , i have the confidence to go forward!
    Mar 2009
    KZN, South Africa
    64
    2,212
    If this is a HWHP, with integrated storage tank, then the condenser coils are mounted on the outside of the tank. The hottest temperatures are at the top of the coil, closest to compressor discharge i.e. at the top of the tank.
  1. Ice Bank Tank for Chilled Water
    By Samarjit Sen in forum Commercial
    Last Post: 31-10-2009, 09:18 AM
  2. pure water from air
    Last Post: 26-02-2009, 12:25 PM
  3. Need Help with cold water tank design
    By ac_sheldon in forum Industrial
    Last Post: 21-11-2008, 11:24 PM
  4. Building a wine cabinet
