Results 1 to 12 of 12
Thread: vacuum confusion
10-04-2010, 06:01 AM #1
vacuum confusion
hello all
not only new to this site but fairly new to refrigeration. I took the plunge and bought myself some cheap and nasty digital gauges with a built in vacuum gauge. When using the gauge it reads 0 for atmospheric and reduces as the vacuum draws to -762 microns or -1013 millibar. to me this does not corelate. Is it me, can perhaps one of you gents enlighten me. Surley those microns should be torr?
10-04-2010, 10:37 AM #2
Re: vacuum confusion
Its just different units of measurement, if I could work out how to post files I would include a conversion chart, I use an analogue Torr gauge as I prefer them to the electronic type.
CheersTutto il Mondo e un Paese
10-04-2010, 06:33 PM #3
Hi, fusbblood
welcome to RE forums,
please search forums for "vacuum", "vacuum units" ... and similar words, for sure you will find some good explanation..
or follow those links to find more links within posts
http://www.refrigeration-engineer.co...t=vacuum+units
of course if you try harder you will find more info on RE forums.... good luck ...
Best regards, JosipLast edited by Josip; 10-04-2010 at 06:34 PM. Reason: spelling
11-04-2010, 02:04 AM #4
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
That must be Refco Digimon!
Give it to your kids as new funny toy.Last edited by nike123; 11-04-2010 at 02:31 AM.
11-04-2010, 02:41 AM #5
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
13-04-2010, 10:10 PM #6
In the US we use microns. typically I pull down to 400 microns if this gives you a point of reference.
25-04-2010, 08:21 PM #7
the original confusion is was the reading of -1013 millibar and -762 micron as being the same pressure reading
I have four kids the youngest is 23
I wouldnt trust him with a new toy /
25-04-2010, 08:40 PM #8
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
25-04-2010, 10:25 PM #9
thats what I thought but litterature and decal on gauge says micron!
Back on ebay me thinks!!
25-04-2010, 11:53 PM #10
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Than search for Digicool!
And buy vacuum gauge separately.
26-04-2010, 01:03 AM #11
just found how to add a signature
and the edit button
off to do some work now on nightsLast edited by fusbblood; 26-04-2010 at 01:06 AM.
It is better to ask a silly question and look stupid for a few minutes than not ask a silly question and remain stupid forever.
26-04-2010, 08:17 AM #12
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
762 microns is 1,01592mbar
prefix - is probably there to indicate pressure below atmosphere!
But then again -1013 mbar mean that vacuum is down to 0,25 mbar absolute or 187,52 microns.
So, it remain unclear which is it, 762 microns or 187,52 microns.
Vacuum Pump Questions
By position1 in forum FundamentalsReplies: 7Last Post: 08-10-2009, 02:33 AM -
Vacuum cleaner as a vacuum pump
By chemi-cool in forum Chit Chat & Service StoriesReplies: 18Last Post: 14-08-2009, 10:11 PM -
Troubleshooting a vacuum pump and gauge set.
By Old Codger in forum FundamentalsReplies: 7Last Post: 08-08-2008, 05:13 PM -
inverters pulling vacuum
By bangoman in forum Air ConditioningReplies: 2Last Post: 05-02-2008, 09:12 PM -
Vacuum test
By Peter_1 in forum FundamentalsReplies: 15Last Post: 13-10-2006, 09:04 PM
