09-04-2010, 10:20 AM #1
Only first half of Pipes freezing?
Hi there, I have a gas refrigeration system run by a bock fk2 compressor. The system is used in a fish hold on a trawler to keep catch chilled around 2 deg celcius. After replacing a damaged compressor the system hasn't been working correctly.
There are 2 banks of pipes in the fish hold connected to the system. Only the first half of each bank of pipes is freezing/chilling. The warmer of the 2 pipes from compressor to cooling area(passing through water pump area to cool) is running very hot and the other pipe which used to frost up before is only mildly cold.
Head unit is set at -1*c. Hp/lp settings are at 250psi first setting, diff at 20psi and third at 18psi. The lp gauge is Reading 35 and high pressure gauge 65 lb per sq inch.
My knowledge on refrigeration is limited. If anyone could give me advice on what the problem could be and how to remedy it. If more info is needed just ask.
09-04-2010, 02:43 PM #2
Re: Only first half of Pipes freezing?
Hi Bobbin,
What refrigerant is the system on?
What was wrong with the original compressor?
Jon
09-04-2010, 04:08 PM #3
R22, original compressor had bearing damage inside which caused electric clutch to burn out. When I tried changing clutch on old compressor it wouldn't turn so I got a second hand compressor and it's now turning with new clutch installed.
09-04-2010, 05:20 PM #4
Could be lots of things, maybe your 'new' compressor is bad, could be short of refrigerant, could be too much cooling water flow through the condenser, etc.
Did you fit the compressor or did you get a tech to do it?
09-04-2010, 06:44 PM #5
thanks for response
I fitted the compressor. Had it checked recently by a tech to make sure seals etc wherent leaking. He was satisfied with everything when he left though didn't see system running for any length of time. He said when I return next week he would put gas in storage tank and see if any air seperates from it.
09-04-2010, 07:19 PM #6
09-04-2010, 08:45 PM #7
Hi cadwaladr, sight glass shows cloudy for 1 sec when clutch turned on and then clear after that. Not sure what liquid line temp is but if it's temp from lp gauge it's around 9*c and hp gauge around 35*c. The thermostat reads 6*c in the fish hold though it's set for -1*c On the head unit. The water cooling system was cleaned and checked recently and appears to be working as normal. Not sure where expansion inlet valve gauze is located on system.
Beko AP930 Fridge freezing bottom half
By Nunners in forum DomesticReplies: 4Last Post: 24-09-2010, 10:21 PM -
Quick freeze in brine solultion vs blast freezing seafood??
By lhwang78 in forum CommercialReplies: 9Last Post: 19-06-2010, 04:48 AM -
Quick freezing of fresh products
By maxim971 in forum Technical SpeculationsReplies: 12Last Post: 18-09-2009, 11:06 PM -
Freezing Time
By M.JAFARI in forum Technical DiscussionsReplies: 1Last Post: 22-11-2006, 07:05 PM -
Freezing problem
By MajinDave in forum Trouble ShootingReplies: 10Last Post: 15-07-2006, 12:01 AM
