Results 1 to 2 of 2
    Mar 2010
    Bangladesh
    40
    151
    15
    Evaporator air flow rate
    I want to know how to check the evaporator flow rate? Actually i want to know the basic of flow rate & the procedure of troubleshooting with the help of evaporator air flow rate.
    Aug 2007
    Sydney
    52
    1,083
    23
    Re: Evaporator air flow rate
    What is the size of your evap and do you have good access to measure face velocities without disturbing the airlfo. If big and yes - hire a velocity grid to measure the face velocity and take 12 to 100 readings depending on coil size, then average out your velocities and muliply by the area this will give you airflo rate. Also take the static pressure readings from before and after the coil. If you can't do this then hire a ballancing technician to do it for you.
  1. Water flow rate.
    By philjd26 in forum Air Conditioning
    Last Post: 19-11-2009, 10:58 PM
  2. Flow Rate through Fan Coil Unit
    By deepu in forum Air Conditioning
    Last Post: 21-07-2009, 06:42 AM
  3. Capillary Tube Characteristics
    By Chef in forum Fundamentals
    Last Post: 10-03-2009, 01:03 PM
  4. high volume flow rate
    By cakabo28 in forum Technical Discussions
    Last Post: 04-10-2007, 03:41 AM
  5. Shell/Tube flow rate?
    By reggie in forum Fundamentals
    Last Post: 17-11-2002, 05:41 PM
