Thread: Shell and Tube service life
06-04-2010, 04:33 PM #1
I've got a pair of ONDA shell and tube heat exchangers used to chill a calcium chloride brine solution to approximately -35°C
What is the expected service life of of such a system?
Are there any steps that can be take to extend the useful life?
16-04-2010, 03:20 AM #2
Re: Shell and Tube service life
Provided you maintain your CaCl2 charge with the proper inhibitors, and the exchanger was designed properly, no reason not to get 20 years plus from the exchanger.
Ken
16-04-2010, 03:42 AM #3
B”H
What is the concentration of calcium chloride to be able to reach -35C.
26-04-2010, 07:20 PM #4
We target a concentration of 1.28 to 1.29.
Someone pushed the concentration to 1.34 the other day thinking more must be better and just about make the whole issue moot by freezing the entire system solid.
Originally Posted by TXiceman
26-04-2010, 09:29 PM #5
Probably the correct ph as well .
27-04-2010, 02:46 PM #6
Try Brinehib from Ashland Chemicals. ( I don't think it's food approved)
Keep the heat exchanger full of brine. If it gets exposed to air by draining the system or similar action, the tubes won't last more than a few weeks.
Minimize turbulence if you have an open system. you don't want excess oxygen in the brine.
Parallel condensers Shell and tube paralle with Evaporative Condenser
By Herschmidt in forum NH3Replies: 2Last Post: 08-06-2010, 11:12 PM -
Fabrication of Cooler Tube & Shell Cooler
By rickyccong in forum Technical DiscussionsReplies: 1Last Post: 27-07-2009, 02:25 PM -
Water velocity in Shell and tube HE
By wilsoncheung in forum IndustrialReplies: 15Last Post: 07-04-2009, 07:59 PM -
liquid level in Shell and Tube flooded evaporators
By cygbob in forum NH3Replies: 3Last Post: 09-09-2008, 04:33 AM -
Help!!! Shell and Tube Evap Leak
By tommy Gun in forum Trouble ShootingReplies: 7Last Post: 22-07-2007, 12:45 PM
