Results 1 to 11 of 11
Thread: Bitzer Screw Compressor
06-04-2010, 08:16 AM #1
Hi, I need the service manual of CSW7582-80-40P Bitzer screw compressor. If any body have please send me. My email is rejan@inbox.com
Thanks & Regards.Last edited by chillin out; 08-04-2010 at 10:19 PM.
07-04-2010, 11:07 AM #2
Hi, rejan
please check this link ...
http://www.bitzer.de/eng/products/docu/doc_det/15
Best regards, Josip
Dear rejan
please do not repeat the same thread twice ... that makes only confusion
be patient, please, someone will answer to you
Best regards, JosipLast edited by chillin out; 08-04-2010 at 10:20 PM.
08-04-2010, 11:37 AM #3
Re: Bitzer Screw Compressor
You may follow this link where you can find more info about this compressor also you can send a request for free CD contains all doccuments,
http://www.bitzer.de/eng/Chiller/CSW...cientificPaper
08-04-2010, 07:44 PM #4
hi rejan as far as i know bitzer don,t produce a service manual ,you only get a spares parts manual and for thrust measure the thrust when you take it apart, and it shouldn,t be more than about 0.08 mm. are you changing the motor stator ,or bearings and the oil filter, let me know and i will try to help as much as i can
09-04-2010, 11:55 AM #5
Hi Ghaz, I want to change the bearings please guide.
09-04-2010, 08:21 PM #6
Hi rejan i will send you an email with the stripdown procedure
10-04-2010, 03:06 AM #7
If you need to change bearings, why ?.
Would be more cost effective to change out the compressor, then re-build as an on shelf replacement.
From previous disasters if bearings are stuffed the whole compressor is non-recoverable. The rotors are/ will be out of spec., and overheat if re-installed.
Are you using the recommend oil, that glue-y synthetic stuff.
magoo
10-04-2010, 07:33 AM #8
Hi Ghaz, Thanks I am waiting for your email.
14-04-2010, 09:53 AM #9
Ghaz/rejan,I had last week burn out of screw Bitzer compressor. Does anyone have service manual for CSH 8551-110y or some other instructions for this compressor, I found some manuals on Bitzer web page...very superficially documentation! Best regards Damir
18-04-2010, 05:07 PM #10
Rejan,....we say here "thanks"
You posted 7 posts only asking for service manuals (Frick, Bitzer and Hitachi) and you never come back here afterwards to thank those who helped you.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
18-04-2010, 08:55 PM #11
Hi dlisjak is the compressor burnt out badley or just the cables been rubbing inside, to change the stator you need to drain the oil out and then take off the winding housing cover off , under the body there is a plug remove it and using a 8mm stud bar pull out the pin ,which goes through the body and the stator ,and then just pull it with lifting aid and the stator will come out easy.if the burned winding particles have gone through the screws ,then just take the complete packout and clean it up slowley ,if you want to change the bearings then make sure you keep the spacers and plate springs together or in the right order they came off , i would set the thrust between 0.04 and 0.06mm if you need any other help with it then let me know and i will write a procedure for you how to dismantle it and repair it ,iv rebuilt couple of these machines and they are very good
YORK Rotary Screw Compressor
By xelazman in forum Industrial CompressorsReplies: 7Last Post: 28-04-2010, 08:37 PM -
Bitzer screw compressor csh8551-110y-35p
By sadiq in forum Technical DiscussionsReplies: 4Last Post: 07-04-2010, 11:13 AM -
problem with volume on frick screw compressor
By samlee12 in forum IndustrialReplies: 4Last Post: 29-10-2009, 07:06 AM -
Screw compressor performance
By faryuki in forum Industrial CompressorsReplies: 12Last Post: 17-12-2007, 04:50 AM -
Screw compressor vibration
By jpumarada in forum Industrial CompressorsReplies: 14Last Post: 26-04-2006, 01:43 PM
