    May 2009
    Australia
    41
    13
    Alco expansion valve
    Does any body know what the kw size of an alco ammonia tx valve Would be model number xb1049az-2b? One of our guys is desperate as the whole plant is shut down untill he can find an equivelant. If need further info I can ask him. Cheer
    Auckland
    74
    3,357
    37
    Re: Alco expansion valve
    Try fitting a hand expansion vav to get plant running manually so-to-speak, and then sort out a Danfoss equivalent.
    Feb 2008
    Las Vegas, NV
    67
    330
    The xb1049az-2b part is similar to Alco's standard refrigerant TEV power head assembly. You'll need the valve body's part number to get the tonnage.
    Thousands of HVACR manufacturers links! Visit: www.hvacrinfo.com
    3,355
    Whats it off and conditions .
    Its probably easier to resize it from scratch .
    May 2009
    Australia
    41
    13
    Apparently they were able to find another valve from somewhere and now it's all good, thanks for the suggestions anyways. Cheers
  1. Can i replace TCLE ALCO expansion valve with TERE type
    By Msanad in forum Trouble Shooting
    Last Post: 28-04-2009, 03:06 AM
  2. Actual Expansion Valve Process
    By AastroGuru in forum Fundamentals
    Last Post: 03-02-2009, 09:53 AM
  3. Need Divine Intervention - plugged drier or expansion valve?
    By archibaldtuttle in forum Trouble Shooting
    Last Post: 08-06-2008, 06:52 PM
  4. Alco Expansion Valve
    By clum in forum Trouble Shooting
    Last Post: 03-12-2007, 05:42 PM
  5. Replies: 2
    Last Post: 07-09-2005, 03:07 PM
