Results 1 to 12 of 12
    quinn148's Avatar
    quinn148 Guest
    High Temp Compressor
    We are currently designing a heat pump to recover waste heat from a 55 C bath and pump it to a 95 C bath. We are looking at using a mixture of R152a and R245a. Which in studies has provided a good response in the 90-100C heating range. In the particular study the experiment was run using R 134a compressor. I’m wondering if anybody has any recommendations for 5-6 kW compressors that can handle discharge temps in the 100 C range.
    Jul 2006
    CN
    Re: High Temp Compressor
    Hitachi products may have this type.
    Aug 2009
    New Zealand
    2,554
    26
    Quote Originally Posted by quinn148 View Post
    All compressors can handle discharge temps of 100C, not a problem. looks like a commercial dishwasher to me?
    fpierson's Avatar
    fpierson Guest
    I have a Bristol 12 ton r22 unit in a similar application running r 416. Was originally R12. The Manufacturer used a smaller displacement compressor due to the high head pressures and temp's. The Kiln manufacturer also used copemetics and Carlile compressors. I have recorded discharge temps of 127C with condenser ambient of 74C. Only one Compressor replacement since 1990. One evaporator, 4 expansion valves and one distributor.
    jafet ferdhy's Avatar
    jafet ferdhy Guest
    i suggest you to use 2 stage compressor. its usually design as rotary type compressor (2 cylinder type)...
    Mar 2006
    Merate (LC) - Italy
    2,549
    R744 transcritical compressors can handle discharge temperatures in excess of 150°C
    Jan 2008
    lanxi city, zhejiang ,china
    45
    14
    Quote Originally Posted by NoNickName View Post
    who can supply this kinds compressor ?
    thanks
    Mar 2006
    Merate (LC) - Italy
    2,549
    Quote Originally Posted by ryanzhao View Post
    thanks
    Dorin, Frascold, Bitzer just to name a few.
    leursky's Avatar
    leursky Guest
    helloooo guys,
    suction pipeline is freezing most of the time & i notice thata the pressure @ low side is to low, how it is happen & whay? anyone can share the idea...
    Apr 2001
    79
    5,071
    35
    It's not about the compressor handling the discharge temp, it's about the oil handling the discharge temp.
    Mar 2006
    Merate (LC) - Italy
    2,549
    Quote Originally Posted by leursky View Post
    helloooo guys,
    What is it? Describe the system and components.
    Also report expected temperatures and readings.
    Limelite's Avatar
    Limelite Guest
    sounds like restricted evap air flow, maybe plugged filter, dirty coil anything causing low air flow.
  1. copeland scroll durability
    By Third_techtrio in forum Technical Discussions
    Last Post: 23-01-2010, 04:47 AM
  2. How to Design Refrigeration Systems
    By US Iceman in forum Fundamentals
    Last Post: 24-07-2008, 04:27 PM
  3. Compressor Pressures at High Ambient Air
    By Andreas11 in forum Air Conditioning
    Last Post: 18-04-2008, 09:28 AM
  4. norlake walkin troubles (bad compressor?)
    By flyboy3b in forum Trouble Shooting
    Last Post: 21-11-2007, 08:45 PM
  5. High Disc Temp
    By road31 in forum Industrial
    Last Post: 15-09-2006, 08:47 AM
