Results 1 to 2 of 2
    Amartin73's Avatar
    Amartin73 Guest
    Frick compressor TDSH193
    Good Morning,
    I was on line looking for a TDSH193 Repair manual and found several on this site asking for the same thing. I have the parts Manual and that is easy to find on line. The actual repair manual, not so easy. If anyone knows how I can get one, point me in the right direction or can send me one that would be great. andymartin540@gmail.com.
    I have a second question; What is considered A high DP for the oil filter. Running dual filters and can switch.
    Thank you for any information in advance. Andy
    Jan 2006
    Croatia
    68
    2,261
    31
    Re: Frick compressor TDSH193
    Hi, Andy
    Quote Originally Posted by Amartin73 View Post
    Good Morning,
    Hard to say but the best is to switch when you reach 0,8 - 1 bar max (14PSI) or earlier ... take in consideration what is your actual oil pressure to not trigger oil safety pressure switch..
    The good maintenance is to switch over at 0,5 bar and clean the dirty one no need to force anything ...
    Best regards, Josip
  1. Frick suction check failure
    By CanadianIce in forum Industrial Compressors
    Last Post: 08-04-2010, 11:43 AM
  2. Frick TDSH 355 oil press. problems
    By SQUATCH1 in forum Industrial Compressors
    Last Post: 15-03-2010, 05:16 AM
  3. problem with volume on frick screw compressor
    By samlee12 in forum Industrial
    Last Post: 29-10-2009, 06:06 AM
  4. problem with frick screw volume
    By samlee12 in forum Industrial Compressors
    Last Post: 20-06-2009, 02:46 PM
  5. Replies: 12
    Last Post: 16-06-2008, 10:06 AM
