Results 1 to 11 of 11
    ArERaIN's Avatar
    ArERaIN Guest
    what is the properties of R134a?
    What is the properties of R134a refrigerant...could everyone there explain it..
    Jul 2008
    London
    848
    Re: what is the properties of R134a?
    In your hand It's a cold clear liquid, then it's a gas -then it's gone..
    Nov 2005
    New Zealand
    550
    Quote Originally Posted by ArERaIN View Post
    Try GOOGLE in future
    Physical properties
    The ideal refrigerant has good thermodynamic properties, is unreactive chemically, and safe. The desired thermodynamic properties are a boiling point somewhat below the target temperature, a high heat of vaporization, a moderate density in liquid form, a relatively high density in gaseous form, and a high critical temperature. Since boiling point and gas density are affected by pressure, refrigerants may be made more suitable for a particular application by choice of operating pressure. These properties are ideally met by the chlorofluorocarbons.
    Corrosion properties are a matter of materials compatibility with the mechanical components: compressor, piping, evaporator, and condenser. Safety considerations include toxicity and flammability.
    My wife used to say you never listen to a word I say at least I think that what she said
    Mar 2010
    Dammam
    83
    15
    There are numerous search engines here in the Net my friend. Reading is the best answer to some of our querries.
    Mar 2009
    KZN, South Africa
    64
    2,212
    Try CoolPack.
    Aug 2009
    85
    15
    Quote Originally Posted by multisync View Post
    SMART ARSE . why not try and answer the geezers question , and actually help someone instead of being soooo clever . is multisync a code for i know everything about refrigeration / ac . so i can take the PI*S out off people that aint so clever and gifted as you .. i think not .
    Aug 2009
    85
    15
    here goes r-134a .=tetrafluoroethane.or cf3-ch2f.it has a boiling point of-26.3oC and a freezing point of-101oC.its a non flamable gas.it,s colourless,and its odour is slightly ethereal. hope this HELPS and answers your question
    Sep 2008
    East Lancashire
    82
    You can also learn a lot about any refrigerant from Material Safety Data Sheets (MSDS) like this one :-
    http://www.refrigerants.com/msds/r134a.pdf
    And Pressure / Temperature (P/T) charts like this :-
    http://www.watco.com.mx/HTCPressureTemperatureChart.pdf
    Dec 2009
    kenya
    7
    obvious questions always ask for coutious answers.what did you intend to know about R 134a.is it properties of R134 itself as a refrigerant or its good properties in comperison to other refrigerant?
    Mar 2010
    Dammam
    83
    15
    yeah right!,i'm tryin to help him and not give a spoon.
    In fact,i think you should attend GMRC seminars.
    Mar 2010
    Dammam
    83
    15
    Quote Originally Posted by ref717 View Post
    "sorry guys,but pls. let us have mutual respect with each other."
  1. R507 in an R134a compressor: any danger?
    Last Post: 21-12-2009, 12:44 AM
  2. r12 vs r134a minifridges (efficiency)
    By ziddey in forum Fundamentals
    Last Post: 25-06-2009, 06:26 AM
  3. Replies: 5
    Last Post: 01-03-2004, 09:59 PM
