Thread: Cooy or Cosy - Soft Starter
31-03-2010, 11:38 AM #1
I have a Cooly or Cosy COCD361PH unit installed and would like to ask if the compresor starter module noted as "ACS", page 7 of the manual, is in fact a soft starter.
If not can a unit like the Invertek [AUST] - XFE Energy Optomising Softstarter be used instead.
Please refer this post to other forum areas if this is not the appropriate location.
With thanks,
Lumpy20.
31-03-2010, 11:08 PM #2
Re: Cooy or Cosy - Soft Starter
Sadly we do not have the manual that you refer too so giving a suitable answer is a bit tricky.
01-04-2010, 04:18 AM #3
Lumpy2
What does the soft starter look like?moulded resin covered about 100mm x 60mm?
lj
05-04-2010, 11:57 AM #4
Hi Lawrence1
Since my last post I have established that the compressor motor is a single phase - DOL- [direct on line] PCS [perminant capicitor start-run] motor.
It would benifit from a Softstarter of VFD and am working on that now.
Also need a solution to one only RTd temp sensor in the house. I would like to have two or three RTD's on the machine to reduce overall run time.
Regards,
KH
electric starter panel for chiller
By Masdede in forum ElectricalReplies: 2Last Post: 26-06-2009, 10:45 AM -
where to get soft starter relays?
By paul_h in forum ElectricalReplies: 10Last Post: 24-03-2008, 02:33 PM -
SCR short in soft starter.
By mrsparky in forum ElectricalReplies: 0Last Post: 14-12-2007, 12:19 PM -
Hard start, Soft Start, Inverter???
By tkc100 in forum FundamentalsReplies: 9Last Post: 28-07-2007, 09:47 PM -
York Water cooled solid state starter?
By Dave the Fridge in forum Trouble ShootingReplies: 6Last Post: 27-03-2007, 05:03 PM
