Thread: Thermo King - Magnum
31-03-2010, 03:54 AM #1
Hi, I am new here and seeking some professional advice, I am handling a case on reefer but have no much knowledge of a reefer.
We have a Thermo King unit (Magnum) the malfunction where the initial data downloaded reflect the following.
Code 18 - Power supply Phast error
Code 59 - Delta Cur error
Under what circumstance will we have this error code?
Appreciate some help.
Rdgs/Vic
03-04-2010, 01:11 PM #2
Re: Thermo King - Magnum
Vic,
Good day to you..Its probably the PCB have fault.Try to check some fuses in the power line and also some phase detector.
Thermo King SB 310 Manual
By Reefer tech in forum FundamentalsReplies: 1Last Post: 15-04-2010, 07:11 PM -
please help! thermo king wiring
By micki_kp in forum TransportReplies: 3Last Post: 17-11-2008, 08:59 AM -
Thermo King Refrigerant Help!
By jingua_ph in forum TransportReplies: 43Last Post: 12-04-2008, 01:19 PM -
Thermo King v? 00 MAX Tc Wiring Diagram
By Chris2005 in forum TransportReplies: 3Last Post: 01-02-2006, 08:01 AM
