Thread: Fujitsu AOY30TMBDL Help Please!
30-03-2010, 08:42 PM #1
Fujitsu AOY30TMBDL. Error Code E:01 = Communication between indoor/outdoor unit. Found T3.15a Fuse blown on outdoor pcb. Board looked knackered and burnt so replaced board. Plugged one thing back in at a time on board and powered up. Last thing to plug back in was the transformer, power up and pop goes 3.15a pcb fuse. I unplugged both connections from tranny to pcb, replaced fuse on pcb and power on - no popped fuse. I plug in the 2 purple leads from tranny into pbc and power on - no popped fuse. Once the other plug from the tranny is plugged into board the fuse pops, suggesting tranny is at fault. I have tried 2 other known to be ok trannys, and the fuse keeps blowing! Any ideas anyone? Many thanks in advance...............
30-03-2010, 09:19 PM #2
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Re: Fujitsu AOY30TMBDL Help Please!
It is probably fault at PCB. Unplug everything except transformer and PCB and try again.
30-03-2010, 09:26 PM #3
Isn't the tranny just for the main power relay coil? (12v)
30-03-2010, 09:42 PM #4
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
30-03-2010, 09:47 PM #5
It is fine until the transformer's 2 red wires (pressuably the low voltage supply) is plugged into pcb. Tried 2 other trannys - still the same.
30-03-2010, 11:11 PM #6
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
31-03-2010, 12:57 AM #7
Tranny supplies low voltage (5, 12 & 24v to PCB. If the fuse is still blowing then a low voltage function is shorting out. Fuse only blows when tranny supplies power to low voltage.
Fujitsu AOY90TPAMF
By andy c in forum Heat PumpsReplies: 6Last Post: 08-02-2010, 04:22 PM -
your opinons on fujitsu please
By acgibo in forum Air ConditioningReplies: 18Last Post: 26-08-2009, 05:06 PM -
fujitsu wall mount volt free relay
By mike live in forum Air ConditioningReplies: 3Last Post: 09-04-2009, 08:26 PM -
Fujitsu PCB
By gwilliamson in forum Air ConditioningReplies: 6Last Post: 10-09-2008, 10:27 PM -
Fujitsu or not?
By LRAC in forum Air ConditioningReplies: 14Last Post: 29-08-2007, 09:45 AM
