    Jun 2009
    Canada
    55
    82
    15
    Frick suction check failure
    Hi guys
    Over the past year I have replaced 4 Frick suction checks that use a rubber seat. The rubber has expanded causing the seat to pop out of the groove it fits in. Obviously the material is incompatible with ammonia or Frick #3 oil. Each of the replacements from Frick had machined metal seats. Has anyone else encountered this problem?
    C Ice
    Apr 2009
    home
    32
    Re: Frick suction check failure
    Yes... Encountered the problem and they are aware of the issue and in the works to fix it.
    Auckland
    74
    3,357
    38
    Hi CanadianIce.
    replace with tephlon,[ spell check ]
    And what was the result with the Petro-Canada oil issue way back.
    magoo
    Jun 2009
    Canada
    55
    82
    15
    Hi Magoo
    I noticed awhile ago that there are two of us with almost the same username. The only difference is mine doen't have a space and his does, however I did follow the post you speak of and my company has had issues with Reflo 68A below 10 F, so we don't use it in applications below this. This oil is not compatible with Buna-N orings but HSN or HBNR don't seem to give us any trouble.
    C Ice
    Dec 2009
    Dubai
    31
    Yes, I recently I have found the O-ring is cut and there is a 5 mm gap.
  1. R290 Suction Scrubber HI Level
    By Knappyfro in forum Trouble Shooting
    Last Post: 28-11-2009, 05:15 PM
  2. 5H86 Failure Investigation Results - Comments Wanted
    By 5H86User in forum Technical Discussions
    Last Post: 17-07-2009, 01:52 PM
  3. Benji
  4. Suction temp
    By Temprite in forum Commercial
    Last Post: 30-05-2005, 10:33 AM
  5. Compressor Check for locked rotor voltage
    By shogun7 in forum Trouble Shooting
    Last Post: 04-04-2004, 12:44 AM
