Thread: CityMulti on BACnet
28-03-2010, 03:07 PM #1
CityMulti on BACnet
I do have 3 black BACnet boxes on CityMulti. No G50 or GA150. Everything on X-cite IQ3; 963 supervisor. So, I can't get fault codes.
Question: how to collect fault codes from Mitsu BACnet controller on Air Con side?
Any free software, or for reasonable price?
/I can't open outdoors, and here ne PAR-21/.
Thank You
P.S.: I haven't design system, client cut on GA150
05-04-2010, 09:17 PM #2
Re: CityMulti on BACnet
As far as I know, fault codes are not "passed on" through the a BACnet gateway, can you nott connect a par27 or Monitor Tool PC somewhere on the system? If you cannot "open outdoors" how will you repair the fault if it is an outdoor unit problem?
"I'm anaspeptic, frasmotic, even compunctuous to have caused you such pericombobulation."
14-08-2010, 08:54 PM #3
Bacnet to Trend IQ3 set up using Mitsubishi Heavy Industries VRF Systems
By 3D AIR in forum New TechnologiesReplies: 1Last Post: 07-03-2010, 12:09 PM -
York Centrifugal
By Peter_1 in forum Industrial CompressorsReplies: 12Last Post: 14-08-2005, 01:25 PM
