Thread: Refrigerant piping design
28-03-2010, 02:01 PM #1
I recently completed an installation of a Liebert unit for a data room. This system consisted of a roof mounted condenser and the air handler section, w/compressor one floor below. The Liebert installation manual requires an inverted trap on both the discharge and the liquid line. I have read in other souces that the trap in the liquid line is not necessary. My understanding is that it prevents liquid from siphoning out of the condenser, and that it prevents liquid from migrating back to the condenser during the off cycle. It would seem to kepp any aditional weight from liquid refrigerant off the L.L. solenoid or the TXV for units without a solenoid. Any input would be appreciated
28-03-2010, 02:49 PM #2
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: Refrigerant piping design
If there is no solenoid valve at liquid line it is possible that all liquid migrate from condenser to evaporator during off period (TXV is never 100% closed) and when compressor start, high risk of liquid in compressor is possible.Last edited by nike123; 28-03-2010 at 03:07 PM.
30-03-2010, 12:48 AM #3
I definately followed the installation manual. I just want to make sure I have a correct understanding of why this is required.
31-03-2010, 01:08 AM #4
I tried to attach the installation manual, for some reason I couldn't make that happen. It does require inverted traps. It looks like they replaced the L.L.trap in your drawing with a check valve? I don't mean to sound like a dope, I'm fairly new to the trade. I've been an electrician for 23 years. I'm what you might call a re-tread!
31-03-2010, 09:03 AM #5
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
31-03-2010, 04:53 PM #6
Thanks very much
Best Refrigerant for New Design
By Andreas11 in forum RefrigerantsReplies: 9Last Post: 05-09-2010, 09:30 AM -
i have some problem choosing Refrigerant for building...
By go1f in forum RefrigerantsReplies: 8Last Post: 08-01-2009, 01:08 AM -
Cable tray for refrigerant Piping
By harsen in forum FundamentalsReplies: 5Last Post: 13-02-2007, 02:02 PM -
refrigerant for water distiller
By star882 in forum RefrigerantsReplies: 0Last Post: 16-12-2006, 05:43 PM -
Replacement fo CO2 Bulk Tank refrigeration unit
By pabs_ref in forum CO2Replies: 31Last Post: 28-11-2006, 10:32 PM
