Thread: maytag problem
27-03-2010, 11:12 AM #1
maytag problem
hi, hopefully someone can help.
i have a maytag gz2626gekb and a few days ago just stoppped getting cold in both compartments. when you open either door you can hear the fan kick in but as soon as you close it it stops.
it has the digital controls for the temp inside the fridge. im hoping to fix it myself if anyone can shed some light on this
many thanks
27-03-2010, 11:01 PM #2
Re: maytag problem
It will need new electronic control (aka jazz board)
28-03-2010, 02:21 PM #3
Re: maytag problem
thanks for the reply , is this a common fault on these?
are these easy to replace mate.
any idea where i can get a control board cheaply in the uk
thanks
02-11-2010, 07:00 PM #4
Re: maytag problem
expensive to replace a few quid shy of £200. About 7 months late to help bodger but these boards fail on the X2 capacitors can`t remember the valve of caps but about 20p each, open door fridge kicks into life close door comp stops caps part of mains voltage dropper for circuit board.
problem with GE air con power problem
By Richie101 in forum Air ConditioningReplies: 6Last Post: 05-11-2009, 04:00 PM -
Samsung Vivace Problem AQV24VBCN
By goldpau in forum Air ConditioningReplies: 0Last Post: 18-09-2009, 06:28 PM -
Saunier Duval Problem
By mallorcanangel in forum Air ConditioningReplies: 1Last Post: 10-07-2009, 01:26 AM -
Maytag side by side auto defrost problem
By m0t in forum DomesticReplies: 4Last Post: 02-06-2008, 12:47 PM -
Furance problem
By ALONEI in forum Trouble ShootingReplies: 10Last Post: 14-05-2008, 11:32 AM
