Results 1 to 8 of 8
    Mar 2010
    uk
    44
    9
    cornilius zenith 900 bottle cooler re-gas question
    I have a cornilius zenith 900 bottle cooler running on R134a which i want to regas. Im used to working on systems with hi/low side charging points but this only has 1 port on a 4 inch pipe going into compressor. Is this a low side charge point?
    Many thanks....
    Jul 2006
    norfolk
    737
    Re: cornilius zenith 900 bottle cooler re-gas question
    yes sure is
    Mar 2010
    uk
    44
    9
    thank you very much
    Mar 2010
    uk
    44
    9
    what is the correct procedure set up to reclaim with only 1 port as i am used to using the push pull method but with only 1 port whats the best way to do it?
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by jack-ice View Post
    Connect your suction side of reclaim unit to that port and in 10 min you are finished!
    May 2006
    Isle of Wight, Uk
    47
    424
    Do yourself a favour and change the filter drier + blow capilary through with ofn first. That's probably whats giving you low gas symptoms - partial or total restriction. Clean the condenser, change the fan, and clean the mesh filter in the tray underneath - it may live again.
    Andy
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by Andy AC View Post
    Andy
    What makes you think that there is some problem.
    It is nowhere in this thread said that there is any problem.
    Mar 2010
    uk
    44
    9
    yeah sorry the problem is that the compressor is not kicking in and ive checked the supply to the compressor and getting 440v so was thinking either the compressor has siezed, low on gas, or thermostat problem....im new to the domestics side im used to car a/c and large fridge plants so still learning.
  1. Conversion of Reach-in Cooler Question
    By tday99 in forum Technical Discussions
    Last Post: 16-05-2009, 06:54 AM
  2. Bottle cooler tripping
    By dunny123 in forum Electrical
    Last Post: 20-06-2008, 10:20 PM
  3. Bottle Cooler on Propane
    By smpsmp45 in forum Domestic
    Last Post: 13-09-2007, 12:07 PM
  4. Bottle cooler
    By Dave M in forum Domestic
    Last Post: 05-09-2007, 11:52 PM
  5. Quest bottle cooler
    By Andy AC in forum Commercial
    Last Post: 24-06-2007, 11:32 AM
