Thread: Recovery of R23
25-03-2010, 04:51 PM #1
Recovery of R23
Does anyone out there know the best way to recover a large amount of R23 other than just using a chilled evacuated high pressure cylinder?
I cant find a recovery pump that is suitable for high pressure gasses of the type of R23,R508b etc
C
26-03-2010, 12:21 PM #2
Re: Recovery of R23
Good question Chris, struggled exactly over this problem end last year and for me, it's impossible to do this.
You have to vent it to the atmosphere unless you recover it to several cylinders and pressurize those all to 20 bar.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
26-03-2010, 07:15 PM #3
Re: Recovery of R23
Previous thread on this subject came up with a few ideas...
http://www.refrigeration-engineer.co...read.php?t=840Brian - Newton Abbot, Devon, UK
26-03-2010, 07:54 PM #4
27-03-2010, 03:55 AM #5
Re: Recovery of R23
Is the system you are recovering from operational ?
13-04-2010, 08:57 PM #6
Re: Recovery of R23
You may already have solved the problem, but anyways here is a way to recover the most.
if possible freeze your recovery cylinder to the lowest possible, if you have access to low temp freezer, then use this, alternative a cold room.
the trick is simply to let the refrigerent run from the warm unit to the cold cylinder, best result is if you can have your cylinder keept in the cold, it will take some pretty long time
it a long distance i on site simply make !/4 pipe between
Is this normal with a CR 700 recovery unit?
By AlexLPD in forum Trouble ShootingReplies: 6Last Post: 13-04-2010, 07:40 PM -
Is Air Content Analyzer Required on Recovery Cylinder?
By A1_Autos in forum Air ConditioningReplies: 9Last Post: 26-03-2010, 07:48 PM -
Can ITE Mini R Recovery Unit recover Liquid?
By A1_Autos in forum Air ConditioningReplies: 8Last Post: 22-03-2010, 11:51 PM -
complete System Recovery
By absolute-zero in forum Computers & the InternetReplies: 9Last Post: 20-01-2008, 06:03 PM -
Recovery and vacuum equipment
By Larry2 in forum FundamentalsReplies: 2Last Post: 19-07-2006, 12:16 AM
